paulc1978
Aug 18, 2022Aspirant
Orbi connections
I have the Orbi RBR50 (in the lounge fairly close to the garden satellite) with 2 satellites, one in the garden summerhouse (hard wired) and one upstairs. Is it possible to set any devices in the gar...
CrimpOn
Aug 18, 2022Guru - Experienced User
paulc1978 wrote:
hoping there is a way I can dedicate these devices to connect to the garden satellite only which is a very good connection to the main router.
(sigh) if only that were possible, but it's not.
One possible solution is to reduce the transmit power of the entire system so that the router in the house will be less attractive and devices in the garden house will be less likely to switch. It's a setting in the Orbi web interface, Advanced Tab, Advanced Wireless Settings. If this change creates 'dead spots' in the house, then it is a matter of which problem annoys you more.
