eric00998
Jan 28, 2019Aspirant
Orbi connects to R7000 for openvpn client
As Orbi do not support openvpn client, I plan to connect orbi with R7000. I found some ideas from below link.
https://community.netgear.com/t5/Orbi/Netgear-Nighthawk-R7000-and-Netgear-Orbi/td-p/142...
Jan 28, 2019Guru - Experienced User
Please post about this here:
https://community.netgear.com/t5/Orbi/bd-p/Orbi
Also:
https://community.netgear.com/t5/Orbi/Orbi-OpenVPN/m-p/1278053#M6825
https://community.netgear.com/t5/Orbi/OpenVPN-Not-connecting-in-Orbi-system/m-p/1667377#M45913
https://community.netgear.com/t5/Orbi/Netgear-Nighthawk-R7000-and-Netgear-Orbi/td-p/1424315
I would like to know is there any configuration I need to pre-set in Orbi base and satellite
The R7000 wifi is closed. Should I configure the wifi setting in orbi base? Or I can simply connect a cable to orbi base and everything fine?
eric00998
Thanks. I also want to add EX7500 into my network.
May I ask more about your setup?
Modem ->(cable) R7000 -> (cable) orbi -> (mesh wifi) orbi / ex7500
Sorry I am newbie of network installation.
- FURRYe38Jan 31, 2019Guru - Experienced User
You should only need the Orbi system for your wifi needs. EX7500 shouldn't be needed.
