eric00998
Jan 28, 2019Aspirant
Orbi connects to R7000 for openvpn client
As Orbi do not support openvpn client, I plan to connect orbi with R7000. I found some ideas from below link.
https://community.netgear.com/t5/Orbi/Netgear-Nighthawk-R7000-and-Netgear-Orbi/td-p/142...
eric00998
Thanks. I also want to add EX7500 into my network.
May I ask more about your setup?
Modem ->(cable) R7000 -> (cable) orbi -> (mesh wifi) orbi / ex7500
Sorry I am newbie of network installation.
Jan 31, 2019Guru - Experienced User
You should only need the Orbi system for your wifi needs. EX7500 shouldn't be needed.
