nickcharles79
Mar 06, 2018Aspirant
Orbi CONSTANT Restarts, Disconnects, ETC
I have an RBR50 + 3x RBS50 pretty large home. When this system works.....it works fantastic full speed everywhere. I have been fighting this damn thing for 6 months now. I have exhausted every option...
mpf541
Mar 06, 2018Apprentice
Only way I got mine to be reliable again was to use it as a Access Point reather than a router. While it works this way I really want the wired backhaul they took away.
If would be nice if someone from Netgear would at least commect on how long we are going to have to wait for a solution for this issue.
- FURRYe38Mar 06, 2018Guru - Experienced User
You could contact NG support and see if they have a beta build for you to check out if you have exhausted all other means of troubleshooting.
mpf541wrote:Only way I got mine to be reliable again was to use it as a Access Point reather than a router. While it works this way I really want the wired backhaul they took away.
- obstcr1984Jun 15, 2018Aspirant
