nickcharles79
Mar 06, 2018Aspirant
Orbi CONSTANT Restarts, Disconnects, ETC
I have an RBR50 + 3x RBS50 pretty large home. When this system works.....it works fantastic full speed everywhere. I have been fighting this damn thing for 6 months now. I have exhausted every option...
Mar 06, 2018Guru - Experienced User
What is the Mfr and model# of the ISP modem?
How big is your house? Sq Ft####
Can you try the following, factory reset the Orbi router and 1 Satellite. Don't use the other Satellites.
Set up the Orbi router from scratch. Set SSID name and PW.
Dissble Beamforming, MIMO, Daisy Chain and Fast Roaming if you have these options. Later on, re-enable Beamforming only to test.
Set 2.4Ghz for manual channel 11. You can try 1 or 6 as well.
Set 5Ghz for any open or unsused channel. Do a wireless scan to see whos near by. How many nieghbors do you have near by?
Set WPA2 and AES only.
Under Advanced/Advanced Setup/Advanced Wireless Settings disable or uncheck 20/40Mhz Coexistence.
Ensure uPnP is enabled and IPv6 is disabled.
Save all settings and reboot the Orbi router. Run some quick tests to make sure a few devices can connect to the router first and get internet access. Run some speeds tests if you want to.
After all this, set up just 1 Satallite, say no more than 40 feet distance from main router. Run the sync process and let the Satellite synce. If it fails to sync with a BLUE light, move the Satellite closer to the Orbi router. After acquiring a BLUE light. Run some tests with just 1 satellite connected. Leave the other 2 Off line.
I have a 5000 sq ft house and only have 1 Satellite used at the far end of the house from where the Orbi router sites up stairs. About 40 feet between them. Range, coverage and performance is stellar and zero disconnections.
nickcharles79wrote:I have an RBR50 + 3x RBS50 pretty large home. When this system works.....it works fantastic full speed everywhere. I have been fighting this damn thing for 6 months now. I have exhausted every option im ready to just smash the whole system with a sledgehammer to be honest.
- Have tried every possible firmware update. Factory reset after update etc. Turned off auto update and rolled back......EVERYTHING!
-Disabled all the features(mimo, diasy chain, etc)
-Tried all the different channels.
-I even swapped out my RBR50 and tried all this stuff again.
I am currently at the recommeneded V2.0.1.4 and its still complete garbage. Id say at least 4-5 restarts a day and constantly disconnects.
I am just at a complete loss. No idea what to do now. Is there a new beta firmware? ANy other suggestions?
Please god help. My family is driving me crazy since this thing is contantly going out. I have put in countless hours troubleshooting myself and with techs. Spent about $900. Unbelievable...HELP!
nickcharles79
Zoom 16x4 model 5370
6000 sqft plus front and back yard. Need the extra sats for front and back.
Pretty much done all this a few times. Ends up doing the same thing eventually.
One thing I cant do is run in AP mode. When i try to switch over it just crashes and i have to do a factory reset. ANy suggestions on how to switch to AP mode?
ANyone have the 2.2 beta firmware?
- FURRYe38Mar 06, 2018Guru - Experienced User
Ok, just making sure modem is stand alone only. Which is why AP mode won't work, you need a router in front of the Orbi when in AP mode.
Give my suggestions a try with one Satellite first. Then we'll add a 2nd. 5000sq ft is good with just one. However I'm sure the buiding lay out is much different.
Beta can only be given by NG support. If you want to, phone it and ask.
nickcharles79wrote:Zoom 16x4 model 5370
- nickcharles79Mar 06, 2018Aspirant
lots of neighbors but i have tried all the different channels and combinations.
How many and what channels are they using? I presume some are spread accross 1, 6 and 11?
How many on each channel.
You maybe in a wifi congested area.
You might try lowing the Transmit Power Control found under Advanced/Adanced Settings/Wireless Settings. This will generate a smaller wifi broadcast foot print which may help in some interferences from other neighbors. You may have to move the 1 Satellite a bit closer if you try this.
nickcharles79wrote:lots of neighbors but i have tried all the different channels and combinations.
