ModManDoc
Dec 16, 2018Follower
ORBI, Cost effective expansion - 2 RBK53s?
I have a difficult home to have complete wifi coverage. Currently I have 3 ASUS routers using their AiMesh system over ethernet and I have not been happy with the coverage. Also, AiMesh seems to not ...
ekhalil
Dec 17, 2018Master
ModManDoc wrote:
............. can I purchase 2 RBK53s and dasiy chain the 4 satelites to one router and use the second router as my dedicated office VPN router?
Totally gree with what CrimpOn said. Yes, you can use all 4 satellites from the two RBK packages and connect them all to one router. You can use the other router for a dedicated VPN towards your office VPN server. You need to sort out how to provide internet to the two routers.
