dontcare
Feb 09, 2019Tutor
Orbi Country Code
Apple release an update to MacOS today (v10.14.3)
Since updating, my iMac will connect to the WiFi through the Orbi and give me access to my home network so I can access all the NAS's. However...
JoeCymru
Feb 09, 2019Virtuoso
It actually is not the wrong country code. When you select Europe for your area, Orbi country code is DE/GB. Most computers accept this, and DE is used as a default for Europe. The issue lies with Apple and the iMac you just updated. The country code for Orbi is factory set for choice and is not user accesible as is. You may try telenet to get in and change the country to WW. I have not experimented with this so would not want to post any process but there is some indication from other Netgear routers that this is not an uncommon issue with iMac's and Netgear routers in Europe.
