cramm
Mar 19, 2020Aspirant
Orbi coverage - How can a Linksys re3000W be better than Orbi?
Hello, i have a two floor home with a 100 square meters on each floor and I am using a RBR50 in the base floor and a RBS50 in the first floor which are connected through ethernet backhaul. On th...
- Mar 19, 2020
Ok, so the sollution for this was in Regional Settings.
I have chosen Europe, and that limited the txpower to max 18 dBm (63 mW). I have changed the region to Canada for testing and that gave me much more txpower and better Wifi connection to the bedroom. I will play with the settings to see what is the best for me. Maybe i choose Canada and put it on 75% or put it manual with iwconfig.
root@RBR50:/# iwlist ath0 txpower
ath0 8 available transmit-powers :
0 dBm (1 mW)
5 dBm (3 mW)
9 dBm (7 mW)
13 dBm (19 mW)
17 dBm (50 mW)
21 dBm (125 mW)
25 dBm (316 mW)
29 dBm (794 mW)
Current Tx-Power:29 dBm (794 mW)Thank you guys for your suggestions!I really apreciate it.
BR and be safe from the covid-19.
theoak
Mar 19, 2020Luminary
Search this forum for switches. The Orbi is biased to certain types of switches and/or those switches have to have certain features turned off.
Can you pull the switch out of the mix for now and connect the Orbi directly to your modem and see how that works?
cramm
I don't have any problems with connectivity but with coverage. How can a switch interfere with the coverage?
- theoakMar 19, 2020Luminary
FURRYe38 already answered this in the Post 4 above.
If the switch is behaving in certain ways, the Orbi has problems. If you are on a playground, and a kid is a bully or hogging the swing, it will impact your ability to get on the swing. Same thing with the network switch and the Orbi. With regards to switches, the Orbi can only play with certain "kids". I recommend following the advice and recommendations given prior.
cramm wrote:I don't have any problems with connectivity but with coverage. How can a switch interfere with the coverage?
- FURRYe38Mar 19, 2020Guru - Experienced User
OK, wanted to be sure he had the info.
Thank you.
- crammMar 19, 2020Aspirant
I guess these settings are fine for Europe, correct?
0 dBm (1 mW)
6 dBm (3 mW)
8 dBm (6 mW)
10 dBm (10 mW)
12 dBm (15 mW)
14 dBm (25 mW)
16 dBm (39 mW)
18 dBm (63 mW)
Current Tx-Power:18 dBm (63 mW)root@RBS50:/# iwlist ath0 txpower
0 dBm (1 mW)
6 dBm (3 mW)
8 dBm (6 mW)
10 dBm (10 mW)
12 dBm (15 mW)
14 dBm (25 mW)
16 dBm (39 mW)
18 dBm (63 mW)
Current Tx-Power:18 dBm (63 mW)Do you guys got other numbers?
