StevedoreNJ
May 27, 2019Aspirant
Orbi Coverage Question
I'm considering either the Orbi RBK23 Performance Wi-Fi system or the RBK50 Ultra Performance system for our home. Looking at both on Amazon. The RBK23 has 3 units & claims 6000 sq ft of co...
ekhalil
May 27, 2019Master
If -and only if- you can keep the RBK50's Router and Satellite around 30 ft from each other then I would go for that option, for the following reasons:
- The RBK50 has a better backhaul capacity (1.7 Gbps vs. 867 Mbps in the RBK23)
- In a mesh system, the less units you have the better, since you will have less interference from the units on each other, as all units operate on the same frequency.
- The RBK50 has bigger and better antennas providing better fronthaul and backhaul radios.
Good luck!
- StevedoreNJMay 28, 2019Aspirant
Thanks for your reply!
The main unit would be on the ground floor, and the satellite would be almost directly above on the 2nd floor, but about 10 ft further towards the rear of the house; definitely within 30 ft. What I'm most concerned about is getting a good signal to the end of the house with our main TV & Roku; about 50 ft from the Orbi main unit. Is 50 ft too far?
Thanks again.
- FURRYe38May 28, 2019Guru - Experienced User
50 is with in range. Depending upon building materials. Concete and metal will effect wifi signal. Wood and sheet rock, not so much. 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Thanks for the comments; I think I'll go with the RBK50. Worst case, if I can't get good coverage everywhere, I'll buy another satellite.
I should have it in a couple of days, and will be back here when I have problems setting it up. :smileyvery-happy:
