StevedoreNJ
May 27, 2019Aspirant
Orbi Coverage Question
I'm considering either the Orbi RBK23 Performance Wi-Fi system or the RBK50 Ultra Performance system for our home. Looking at both on Amazon. The RBK23 has 3 units & claims 6000 sq ft of co...
May 28, 2019Guru - Experienced User
If you can do with the out the faster backhaul, the 3 unit Orbi maybe more flexible over the RK50 which only comes with 1 satelilte. Haveing additional satellites will give you more options and placements.
Try either one. You can always send it back if it doesn't suit your needs.
