LenP
Dec 22, 2019Aspirant
Orbi crashes multiple times per day
ci I've had this Orbi system for a few months. Performance is great when it works... but the router crashes multiple times a day while the family is watching streaming TV. Very unsatisfying for a ...
LenP
Dec 26, 2019Aspirant
wow, thanks for the response!
Firmware 2.5.1.8
Both Disable Port Scan and DoS protection and Respong to Ping on Internet port are disabled
Distance is probably 20 feet but there is a floor and a wall in between. Signal and backhaul shows "Good"
Dec 26, 2019Guru - Experienced User
Lets move the RBS farther away. 20 feet is still a bit too close. I've had my RBS out at 40 feet with two walls and a roof in between. Still get good signal.
What happens if you enable Port Scan and DoS protection on the RBR?
What other WiFi devices do you have connected to the system. Any devices that broadcast there own wifi signal by chance?
