des421
Apr 27, 2017Tutor
Orbi crashes
1st - the logs are apparently on Pacific time? 3 hrs. behind my CST, can this be set some where? 2nd - the WiFi has disappeared once in the middle of the night. Was able examine the device via th...
des421
Apr 30, 2017Tutor
Nothing like replying to your own post, but just in case it'll help somebody else...
The time zone can be set under Advanced / Security / Schedual in the web interface.
And apparenly even though Netgear doesn'r want to talk to you directly, maybe they do read these! Because my router firmware updated to 1.9.1.12, which isn't even listed on the Downloads page yet. The Satelite stayed on 1.8.1.6 though?
DarrenM
May 02, 2017Sr. NETGEAR Moderator
Hello Des421
The latest firmware is now on the support page in case you need do manually update the satellite.
DarrenM
- des421May 02, 2017Tutor
Updated the Satelite manually, thanks. And now it's also checking for updates well as the Hub. The Satelite used to just sit there saying "wait". Apparently they're getting there!
