des421
Apr 27, 2017Tutor
Orbi crashes
1st - the logs are apparently on Pacific time? 3 hrs. behind my CST, can this be set some where? 2nd - the WiFi has disappeared once in the middle of the night. Was able examine the device via th...
DarrenM
May 02, 2017Sr. NETGEAR Moderator
Hello Des421
The latest firmware is now on the support page in case you need do manually update the satellite.
DarrenM
des421
May 02, 2017Tutor
Updated the Satelite manually, thanks. And now it's also checking for updates well as the Hub. The Satelite used to just sit there saying "wait". Apparently they're getting there!
