PMWICON
Dec 31, 2019Tutor
Orbi creating two different IP Ranges?
Hi All, I am hoping someone can help me. It seems I have two different IP ranges floating around my house. First, a bit about my setup... I have a Netgear ORBI RBR50 with one satelite. I also...
Dec 31, 2019Guru - Experienced User
What modem are you using?
- PMWICONDec 31, 2019Tutor
I have an AT&T moden/wifi router combo. All WIFI capabilities are disabled on the router. I spoke with AT&T for about an hour this morning and we did a bunch of torubleshooting, but the only IP's they see being set on their side are the 192.168.0.x ranges.
- plemansDec 31, 2019Guru - Experienced User
PMWICON wrote:I have an AT&T moden/wifi router combo. All WIFI capabilities are disabled on the router. I spoke with AT&T for about an hour this morning and we did a bunch of torubleshooting, but the only IP's they see being set on their side are the 192.168.0.x ranges.
Disabling wifi doesn't disabling its routing function. You'll still have 2 devices handing out IP addresses on your network.
https://kb.netgear.com/30186/What-is-Double-NAT
I will take a look at this. Thank you for taking the time to help me out!
