PMWICON
Dec 31, 2019Tutor
Orbi creating two different IP Ranges?
Hi All, I am hoping someone can help me. It seems I have two different IP ranges floating around my house. First, a bit about my setup... I have a Netgear ORBI RBR50 with one satelite. I also...
PMWICON
Dec 31, 2019Tutor
I have an AT&T moden/wifi router combo. All WIFI capabilities are disabled on the router. I spoke with AT&T for about an hour this morning and we did a bunch of torubleshooting, but the only IP's they see being set on their side are the 192.168.0.x ranges.
Dec 31, 2019Guru - Experienced User
PMWICON wrote:I have an AT&T moden/wifi router combo. All WIFI capabilities are disabled on the router. I spoke with AT&T for about an hour this morning and we did a bunch of torubleshooting, but the only IP's they see being set on their side are the 192.168.0.x ranges.
Disabling wifi doesn't disabling its routing function. You'll still have 2 devices handing out IP addresses on your network.
https://kb.netgear.com/30186/What-is-Double-NAT
- PMWICONDec 31, 2019Tutor
I will take a look at this. Thank you for taking the time to help me out!
- plemansDec 31, 2019Guru - Experienced User
No worries.
Att devices aren't known to be simple/capable to setup in passthrough/modem only mode. many have to put their orbi's in AP mode to get the functing properly. Not sure why Att is so possessive of keeping their routing function active.
In looking at the instructions noted for fixing the NATing issue.... The suggestion was to put the AT&T device into Bridge mode. As I look at the instructions for how to do this with my particular modem it seems I am already in Bridge mode. In my routers case it is setting the firewall function as "Passthrough".
Not sure this is the issue as it seems my AT&T device has already been set in Bridge mode and the wifi has been disabled.
Att devices are notorious for passthrough dmz not working correctly.
Again, many times the easiest router to get everything working properly is leave the att device in routing mode, disable its wifi, and place the orbi in AP mode.
Its not hard to do and if it fixes your issue, then its the att combo device causing issues.
- SW_Dec 31, 2019Prodigy
Adding to plemans's comments, I would avoid IP Passthrough at all cost because it could create other problem down the road and taxing Orbi CPU with NAT'ing. If you don't have gigabit speed, it might not matter (gigabit + NAT == ~100% CPU on my Asus RT-AC87U).
Having ATT box does all the basic routing/dhcp stuffs + NAT'ing will allow Orbi to focus on WiFi, which is its strength. It doesn't mean that Orbi Quad-core 716 MHz processor can't deal with gigabit download speed. Having Orbi in AP Mode will keep the setup simple and take advantage of the strength of both boxes.
