3LevelTerrace
Feb 27, 2019Follower
Orbi cross floor penetration
Hi All,
I recently moved into a three level terrace apartment with a bedroom and study on the bottom floor, and the living room, dining room and kitchen (open plan) on the middle floor (see the...
ekhalil
Feb 27, 2019Master
3LevelTerrace wrote:
............ In the living room at the top of the stairs the wifi connectivity is ok but signal strength fluctuates (not sure why) - it can go from four bars to two very suddenly. ........
Hi All,
,,,,,,,,,,,,,,. In the living room at the top of the stairs the wifi connectivity is ok but signal strength fluctuates (not sure why) - it can go from four bars to two very suddenly. ..........
- It's very difficult to guess without a wifi scan. Please make a wifi radio scan in your place, specially around the place you plan to place the Orbi Router and Satellites.
- When you see the wifi signal fluctuating in the living room, do you know if the device is then connected to the 2.4 or 5 GHz bands in your current router? If it's connected to the 5 GHz then most pobably Orbi backhaul will work fine because of the following reasons:
- Your current 5 GHz is likely using the low 5 GHz band which can be quite congested in most places. A wifi scan would confirm this. Orbi backhaul uses the high 5 GHz band which is less frquently used and will have lower interference and thus better reacheability.
- The backhaul antennas in the Orbi 50 series (which is recommended in your case) are quite powerful and better than any other home-wifi router, so likely it will provide better backhaul coverage than what you currently experience.
