mgeorgy
Dec 23, 2017Tutor
Orbi Custom DNS
I use a local DNS server to serve a local zone within my LAN. When I use this server as the DNS server in the Orbi the DHCP lease still includes the Orbi's IP as the default. Is there a way to NOT have the Orbi use it's LAN IP as the DNS Server?
I realize this is to allow users to use the http://orbilogin.com feature, but this is not something I will be using in my configuration.
1 Reply
- guzzijasonApprentice
By default, the Orbi receives your ISP DNS servers vi DHCP. It then has a local caching DNS server (dnsmasq) that forwards requets to the upstream server(s).
If you override the DNS servers in Advanced -> Setup -> Internet Setup, you can have the Orbi forward DNS queries to your internal nameserver instead.As for the majic that makes "orbilogin.com" DNS work, I haven't quite figured that out, TBH. I have my laptop explicitly cofigured to use my upstream ISP DNS servers, but orbilogin.com *still* works. I suspect they are doing some sort of packet inspection/rewriting of DNS queries coming through the Orbi to make that work, but i'm not sure yet. Now that I'm looking at that, though, I am very curious to see how they are doing that, and if it can be disabled if someone chose to...
