LosAngelesUSA
Jun 12, 2018Follower
Orbi Customer Support
Our orbi drops the internet up to five times a day requiring a power cycle.
Orbi has the worst customer service I have ever experienced. It takes twenty-thirty minutes for someone to pick up th...
mldavison
Jun 28, 2018Aspirant
I actually have an RBR20 and it drops service constantly - need help configuring it to work with my Ubee Spectrum router. Does anyone have a phone number I can call for Netgear support? Once I registered the product the screen went blank with support options. Ready to return this after days of frustration!!
- FURRYe38Jun 28, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, LAN to LAN and configure AP mode on the Orbi router.
- mldavisonJun 28, 2018Aspirant
I recently switched it to AP mode. Hoping that will help...
