kelvin1128
May 24, 2017Tutor
Orbi cut my speed in 1/2
I currently have Verizon Fios gigabit internet, when I connect my laptop via Cat5E directly to the Fios Gateway, I get about 800 mbps. However when I do the same speed test right next to the "home ba...
- May 24, 2017Try to go to the QOS settings in the advance tab run speed test there. See if that reset anything. If not u can try to disable the QOS to see if it help. Orbilogin.net/QOS_main.htm
st_shaw
May 24, 2017Master
Is your laptop wired to Orbi or is it connected tobOrbi via WiFi? It's not clear from your description.
kelvin1128
May 25, 2017Tutor
st_shaw both actually, hardwire and wireless..
