kelvin1128
May 24, 2017Tutor
Orbi cut my speed in 1/2
I currently have Verizon Fios gigabit internet, when I connect my laptop via Cat5E directly to the Fios Gateway, I get about 800 mbps. However when I do the same speed test right next to the "home ba...
- May 24, 2017Try to go to the QOS settings in the advance tab run speed test there. See if that reset anything. If not u can try to disable the QOS to see if it help. Orbilogin.net/QOS_main.htm
kelvin1128
May 25, 2017Tutor
st_shaw both actually, hardwire and wireless..
st_shaw
May 25, 2017Master
Wired or wireless makes a difference. With your laptop wired to the Orbi Router you should get your full speed. Wired to the satellite you should get around 500 Mbps. Wireless will be slower and you should get between 200 and 450 Mbps, depending on the laptop's capabilities.
