Yld2rob
Jan 09, 2017Luminary
Orbi Daily Disconnects
Wow. The latest firmware update has made the Orbi start disconnecting a few times a day. Going to revert back to the old firmware version. I am afraid that the router will auto update to the most rec...
geh4
Jan 25, 2017Tutor
I have been experiencing the same issue after updating the router and satelite to the latest firmware.
- DarrenMJan 26, 2017Sr. NETGEAR Moderator
Hello geh4
You may want to position your satellite a little further away you could be seeing the disconnects because the device is jumping back and forth between units.
DarrenM
