Yld2rob
Jan 09, 2017Luminary
Orbi Daily Disconnects
Wow. The latest firmware update has made the Orbi start disconnecting a few times a day. Going to revert back to the old firmware version. I am afraid that the router will auto update to the most rec...
geh4
Jan 25, 2017Tutor
I have been experiencing the same issue after updating the router and satelite to the latest firmware.
DarrenM
Jan 26, 2017Sr. NETGEAR Moderator
Hello geh4
You may want to position your satellite a little further away you could be seeing the disconnects because the device is jumping back and forth between units.
DarrenM
