Yld2rob
Jan 09, 2017Luminary
Orbi Daily Disconnects
Wow. The latest firmware update has made the Orbi start disconnecting a few times a day. Going to revert back to the old firmware version. I am afraid that the router will auto update to the most rec...
Jamessimmering
Jul 12, 2017Star
Once again, I have more disconnects. But NOW... the system won't re connect. I have to close out my wifi on my device and restart to have it reconnect.
The best system for me was right out of the box. The issues started with the first firmware update and continue to this date.
I am using the most updated firmware. 1.12.0.18. Also it is now disconnecting WIRED Devices. It wasn't doing that before.
any help anyone? I had real hope for this version. I feel like charly brown trying to kick the football.
jim
DarrenM
Jul 14, 2017Sr. NETGEAR Moderator
Hello Jamessimmering
Have you done a full factory reset on the unit?
DarrenM
- WendyWJul 20, 2017Aspirant
I've done the full resets and still have this cutting in and out to no Is Netgear going to address this issue or not??
- JamessimmeringJul 20, 2017StarI had the same issues. Do you have beam forming and mu mimo turned on? That seemed to have fixed the disconnects for me ( that and the latest fiemware). Lemme know if that fixes it for you. Jim
