Yld2rob
Jan 09, 2017Luminary
Orbi Daily Disconnects
Wow. The latest firmware update has made the Orbi start disconnecting a few times a day. Going to revert back to the old firmware version. I am afraid that the router will auto update to the most rec...
DarrenM
Jul 14, 2017Sr. NETGEAR Moderator
Hello Jamessimmering
Have you done a full factory reset on the unit?
DarrenM
WendyW
Jul 20, 2017Aspirant
I've done the full resets and still have this cutting in and out to no Is Netgear going to address this issue or not??
- JamessimmeringJul 20, 2017StarI had the same issues. Do you have beam forming and mu mimo turned on? That seemed to have fixed the disconnects for me ( that and the latest fiemware). Lemme know if that fixes it for you. Jim
