steeve725
Mar 11, 2019Guide
Orbi Daisy Chain & How long before something connects to satellites
Ok Guys.
A couple things that kind of confuse me and I'm wondering.
First off on my RBK33 with the plug in satelittes I have them hooked up again with the 2nd satellite just to see how th...
ekhalil
Mar 12, 2019Master
steeve725 wrote:
........................ my ring floodlight camera thats mounted on the outside my house. Its mounted on the same wall as my living room satellite is located inside. A couple times it wont show up on my orbi app connected to any device, ...............
It can be that the camera is actually on the "Atached Devices" list but it can be with the wrong name! I noticed that Orbi can give some devices a random name (a name for another device in your network) if the device does not specify a name to Orbi during attach procedure.
So please look carefully in the attached devices list, look into the MAC addresses and check if the camera's MAC address is there. If you find it then just rename it to the correct name :)
schumaku
Mar 12, 2019Guru - Experienced User
Reads like a familiar problem - attached device information and their optional configured names show either wrong - or not at all - on many Netgear Nighthawk router for years. Why do I don't wonder one second? We read the same now for Nighthawk AX, for Orbi, ... Appears Netgear does not care at all.
