Retired_Member
Nov 30, 2017Orbi Daylight Savings Time (DST)
I read in the Orbi manual that the DST adjustment is disabled (default). I live in the U.S. eastern time zone and we do adjust for DST. Do I need to adjust the DST setting in the Orbi?
Hydro130
Dec 06, 2017Luminary
Log in to your Orbi management page (usually http://192.168.1.1), then go to the Advanced tab on the left, go down to the Security section, then click on Schedule.
At the bottom of that resulting screen, you can set your local time zone and DST preferences.
- Retired_MemberDec 06, 2017
Thanks for the replies
i haven't made any changes. Closer look at the settings indicates the DST setting is for setting up a timed web event? I don't need that.
