tsulsenti60
Oct 08, 2020Aspirant
ORBI: Devices on LAN network cannot communicate with each other
I have an Orbi router in AP mode connected via ethernet to a Netgear C700V2 Gateway with Wifi turned off. I have two satellites. My devices gather the appropriate LAN private IPs as specified in the ...
- Oct 09, 2020
Would you mind indicating what the solution was?
And, it helps if the post is marked "Solved" so that others know the issue is closed.
tsulsenti60
solved nvm
- CrimpOnOct 09, 2020Guru - Experienced User
- tsulsenti60Oct 09, 2020Aspirant
The solution was my own error in firewall settings. Turning it off fixed it. Obviously this is unsecure so i will have to investigate where exaclty the block is.
