Japex1's avatar
Japex1
Orbi Devices
Hi
Im looking for a WiFi System to replace my NightHawk...
I'd like to know if into Orbi's system is possible to add multiple Orbi devices or 3 is the limit.
And also if Orbi is a MESH system... im new to this discussion, but is MESH a better solution then Router + Repeater?
Thanks
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Japex1
    Orbi is a star topology and you can have a router and 3 satellites. And yes this has alot more advantages than a repeater such as full wireless speed, single network SSID and seamless roaming.
    DarrenM
    • Japex1's avatar
      Japex1
      Thanks.
      Is it better then MESH system like Asus Lyra?
      And may i add more then 3 "antennas" to the Orbi system?
      • DarrenM's avatar
        DarrenM
        Hello Japex1
        Community members have had success adding more than three but it is not recommended by Netgear
        DarrenM
