ed1chandler
Nov 27, 2017Aspirant
Orbi DHCP address range configurable?
It would *appear* that, no matter what IP and subnet mask you tell Orbi to use, DHCP will only assign the first 252 addresses. (i.e. If you change to 172.16.0.1\22, Orbi will only open the last octe...
DarrenM
Dec 01, 2017Sr. NETGEAR Moderator
Hello Ed1chandler
Can you send me a PM with your name, Email, and phone number I want to get you to support to work with you on this issue.
DarrenM
ed1chandler
Dec 01, 2017Aspirant
You're going to need to explain how to do that, since it's not apparent either from this screen, or from your profile screen.
Meanwhile, the Orbi app won't connect either. I see a lot of people having that problem. I guess I'd like to know the app (iOS) knows to connect with your particular Orbi.
- st_shawDec 01, 2017Master
To send a PM: Click on his username. On his profile page there is a big button at the top left that says "Send this user a private message."
- ed1chandlerDec 01, 2017Aspirant
If that were the case, I wouldn't have asked. It says, "Contact me", but only shows his online status and nothing is clickable.
However, *your* profile does have the big button you mentioned.
