ed1chandler
Nov 27, 2017Aspirant
Orbi DHCP address range configurable?
It would *appear* that, no matter what IP and subnet mask you tell Orbi to use, DHCP will only assign the first 252 addresses. (i.e. If you change to 172.16.0.1\22, Orbi will only open the last octe...
ed1chandler
Dec 01, 2017Aspirant
You're going to need to explain how to do that, since it's not apparent either from this screen, or from your profile screen.
Meanwhile, the Orbi app won't connect either. I see a lot of people having that problem. I guess I'd like to know the app (iOS) knows to connect with your particular Orbi.
st_shaw
Dec 01, 2017Master
To send a PM: Click on his username. On his profile page there is a big button at the top left that says "Send this user a private message."
- ed1chandlerDec 01, 2017Aspirant
If that were the case, I wouldn't have asked. It says, "Contact me", but only shows his online status and nothing is clickable.
However, *your* profile does have the big button you mentioned.
- st_shawDec 01, 2017Master
Weird. Darren's profile has the PM button when I view it. If you would like to PM me your details I will forward them to Darren for you.
