w3wilkes
Apr 19, 2017Prodigy
Orbi DHCP Lease Time?
With the Orbi system can I set the DHCP lease time? If not, this is a deal breaker!
- DarrenMSr. NETGEAR Moderator
I will have to check on this.
DarrenM
Out of curiosity, why is this a deal breaker for you? The XY Problem.
- w3wilkesProdigy
I run a Windows Home Server 2011. The Bare metal restore doesn't handle DHCP lease renewel correctly and a Bare Metal Restore fails with Netgear's default 1 hour DHCP lease because a Bare Metal restore runs for more than 1 hour on any of my supported clients. The error after 1 hour of a Bare Metal restore is an "unknown network error". On my old DGND3700v1 the Netgear provided DHCP lease time is 1 hour and from what I've seen this has been the case on all the Netgear routers I've been aware of in the last few years. When I use a router that allows me to set the DHCP lease to a duration longer than a Bare Metal restore runs all is well. I do not believe that MS has fixed the Bare Metal restore TCP/IP stack in more recent server Bare Metal restore so it would not be worth it to upgrade my server as it currently does all I need.
In my case the XY problem doesn't apply. I know what the problem is and how to fix it and Netgear doesn't give me the flexibility to get around the problem MS is giving me.
DarrenM, what is the lease time provided by the Orbi? If it's 1 day then, w3wilkes, your Bare metal restore process should be fine.
It does not have a DHCP lease time.
DarrenM
