w3wilkes
Apr 28, 2017Prodigy
ORBI DHCP Lease Time?
With no ability for the user to set the DHCP lease time on the Orbi system, what is the lease time that Netgear has hard coded in Orbi?
1 Reply
To anyone with an Orbi and Windows, please look at ipconfig /all and post your Lease Obtained and Lease Expires times.
If you have a Mac, open a Terminal window and run ipconfig getoption en0 lease_time and post the value. If en0 doesn't work, then subsititute with the correct interface. Run ipconfig without any options to list all of your interfaces.
