orbiRoss20
Mar 05, 2018Follower
Orbi DHCP static ip Qnap with dual NICs
Router Firmware Version V2.1.2.18 Hi, I have a Qnap NAS with 2 NICs which are both ethernet cabled into Orbi router. How do I assign a static ip address when 2 MAC addresses? Thanks.
Brain29
Mar 05, 2018Apprentice
orbiRoss20wrote:Router Firmware Version
V2.1.2.18
Thanks.
Advanced -> setup ->Lan Setup -> Add to Address Reservation
Its easy to miss if you have no vaules in it already
- most home riad devices are 100% fine with just static ips -- I have 1 fixed and 1 set to dhcp on another switch, the only time I notice it working is if more then 1 person is connected to it. It's kind of pointless unless you have duel lan to your desktop or a few people who might hit the server at the same time - even then you basically need the qnap to be filled with ssd's because spin drives are slow -- why some come with ssd cache ..
