GKACK
Mar 16, 2018Tutor
Orbi did not reconnect after power outage
The Orbi system (2 sattelites and firmware v2.1.2.18) has recovered after a power outage in the past but did not after a longer than usual outage this week. The house is not occupied so recovery and ...
Jun 21, 2018Guru - Experienced User
Default settings for MAC is not cloned. Was this changed at some point during an initial set up?
Even if the ISP modem/service supported cloned MAC, shouldn't loose connection I believe.
Sounds like you found your fix for your problem...
GKACK wrote:
Update on my issue where the router had no internet after the power outage. I continued to have an issue after resetting the Orbi even when I rebooted the router. No internet after the reboot. Sending a signal through Xfinity app to restart the cable modem did seem to work. Then I noticed a setting for the "Router MAC Address" and it was set to Use Computer MAC Address. I changed this to Use Default MAC Address and ever since making that change a reboot resulted in a successful restoration of internet access without a need to send a signal to the cable modem (or unplug it).
Does this make sense?
GKACK
Jun 21, 2018Tutor
I do not remember changing it but the Xfinity tech who came to the house when we were not there and reset the Orbi might have.
I will also note that I had started to use the Netgear dynamic DNS service for remote management access. I switched that off about the same time I changed the MAC address setting and went back to the standard IP address access which always seemed to work anyway. Maybe that was also a contributor to the problem?
- FURRYe38Jun 21, 2018Guru - Experienced User
Well you have two areas that you can try to reproduce if you get curious. Enable both or one at a time, then simulate a power outage by pulling the plug on both router and satellite and see what happens. I don't think DDNS would be a cause...however, anything is possible with Orbi. :smileyfrustrated:
