lowepg
Aug 06, 2018Apprentice
Orbi did not reconnect after power outage
This is the 3rd time this has happened in as many months. Power drops during a storm, come back on quickly. Cable modem resets, connects to internet (I can test this easily). Orbi, however, refu...
RocketSquirrel
Aug 07, 2018Luminary
PS, I forgot to mention that this problem anecdotally is worse when using wired backhaul, which I am. Some users with wireless backhaul report not having this issue. How’s your backhaul set up, lowepg?
- lowepgAug 07, 2018ApprenticeMix of wired and wireless backhaul.
Restarting network without wired backhaul
Seemed to allow me to recover faster this time.- striolaAug 09, 2018Guide
I use wired backhaul and have the same issue of my Orbi system (RBR20 + 2 RBS satellites) not having any functionality after a power outage. Unplugging the ethernet cable from both satellites "fixes" the problem and the Orbi system works again (I don't need to power cycle). I then need to reconnect the wired backhaul on each satellite (which sometimes works on the first try and sometimes takes some trial and error).
UPDATE: Lost power briefly last night and I have been unable to get wired backhaul working again. Tried cycling power, synch button etc. with no luck. Especially frustrating because wired backhaul will work for a few minute while LED flashes white, LED then turns amber and Orbi no longer functions, LED then turns solid blue and Orbi no longer functions. As soon as I remove the Ethernet cable, Orbi works properly.
