Sierraw
Jul 02, 2022Aspirant
Orbi disconnecting AROUND the same time every night
As a heads up, i recognize that similar topics have been discussed, but they either never had a solution, or the solutions provided never worked. At the same time, i've noticed that my problem is a ...
- Jul 05, 2022
Final Final Update: The new router didn't change anything. Seeing as though this affects multiple devices, the only assumption I can make at this point is that it's ISP side, and has absolutely nothing to do with my hardware, which is what i suspected early.
CrimpOn
Jul 02, 2022Guru - Experienced User
Which system is this? (model number from label on the bottom of the router)
Sierraw
Apologies, this is an RBR50v2
- CrimpOnJul 02, 2022Guru - Experienced User
So, the Orbi log get completely cleared and has an entry reading something like "initialized"?
The firmware release that the router was updated to is??
Is this router on a UPS?
- SierrawJul 02, 2022Aspirant
not that i know of, would that be a part of all the wiring i already have set up? and would this affect it at the given times? That's kind of been the most vexing part of this
Firmware was update to the most recent version: 2.7.4.24
as for the question about the logs, correct. =- SierrawJul 02, 2022Aspirant
Also i guess i accidentally misinformed, maybe it's not wiping? i guess the logs were wiped when I was attempting to fix it by unplugging and replugging it. That's my bad
