Sierraw
Jul 02, 2022Aspirant
Orbi disconnecting AROUND the same time every night
As a heads up, i recognize that similar topics have been discussed, but they either never had a solution, or the solutions provided never worked. At the same time, i've noticed that my problem is a ...
- Jul 05, 2022
Final Final Update: The new router didn't change anything. Seeing as though this affects multiple devices, the only assumption I can make at this point is that it's ISP side, and has absolutely nothing to do with my hardware, which is what i suspected early.
Sierraw
Apologies, this is an RBR50v2
CrimpOn
Jul 02, 2022Guru - Experienced User
So, the Orbi log get completely cleared and has an entry reading something like "initialized"?
The firmware release that the router was updated to is??
- CrimpOnJul 02, 2022Guru - Experienced User
Is this router on a UPS?
- SierrawJul 02, 2022Aspirant
not that i know of, would that be a part of all the wiring i already have set up? and would this affect it at the given times? That's kind of been the most vexing part of this
The UPS question was intended to rule out that some goofy power interruption was causing the router to reboot. I have each of my Orbi systems (and my ISP modem) connected to small UPS systems so that those irritating short "blips" in electrical supply do not cause them to reboot.
That log file appears to show the Orbi reporting that it lost internet from the modemand regained it almost immediately. (not that the Orbi rebooted) Good that someone is coming to check the modem. (I once had a cable drop that squirrels had chewed up and as it swayed in the wind the connection would sometimes break.)
Firmware was update to the most recent version: 2.7.4.24
as for the question about the logs, correct. =- SierrawJul 02, 2022Aspirant
Also i guess i accidentally misinformed, maybe it's not wiping? i guess the logs were wiped when I was attempting to fix it by unplugging and replugging it. That's my bad
