Sierraw
Jul 02, 2022Aspirant
Orbi disconnecting AROUND the same time every night
As a heads up, i recognize that similar topics have been discussed, but they either never had a solution, or the solutions provided never worked. At the same time, i've noticed that my problem is a ...
- Jul 05, 2022
Final Final Update: The new router didn't change anything. Seeing as though this affects multiple devices, the only assumption I can make at this point is that it's ISP side, and has absolutely nothing to do with my hardware, which is what i suspected early.
Sierraw
Jul 04, 2022Aspirant
Final Update:
I finally started noticing these issues throughout the normal day as well, and the timing is now inconsistent, so i'm going to be getting a new router. Not sure if i'm getting orbi again, but i'm definitely getting something. Hope this helps someone in the future.
Sierraw
Jul 05, 2022Aspirant
