albertoesq
Mar 15, 2017Tutor
Orbi disconnecting continously
I just bought an Orbi Router + satellite, the first 2 weeks where a dream, excelent speed, WiFi everywhere and almost no hickups, but it had been already 2 weeks of nightmare, disconects every 20 minu...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
lekw310388
Mar 16, 2017Star
I have the same issue, on both IOS and Android devices. Updated to the latest firmware doesn't seems to fix the problem. Still getting signal drop and reconnect every few minutes.
- albertoesqMar 16, 2017Tutor
Your orbi disconects only on ios and android? if you're at a PC it keeps the connection?
- DarrenMMar 20, 2017Sr. NETGEAR Moderator
Hello albertoesq
Have you tried to re position the satellite maybe the units overlapping to much.
DarrenM
- stavrosgApr 07, 2017Star
Same problem here. TV, pc, phone all disconnect like every 40 minutes. I wish i could return it, but missed the deadline.
This is the last netgear product i purchase...
