albertoesq
Mar 15, 2017Tutor
Orbi disconnecting continously
I just bought an Orbi Router + satellite, the first 2 weeks where a dream, excelent speed, WiFi everywhere and almost no hickups, but it had been already 2 weeks of nightmare, disconects every 20 minu...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
DarrenM
Apr 12, 2017Sr. NETGEAR Moderator
Hello Stavrosg
Have you disabled beamforming and mumimo? Tried changing wireless channels? also you could try to lower the power level of the 2.4ghz network.
DarrenM
stavrosg
Apr 12, 2017Star
Nope, will try now.
Switched to AP mode, worked for a day. then this morning every minute.
Currently here is the setup.
AP mode
no MIMO and beam forming
2.4ghz radio is off
1.8..xxx firmware
I'll try channels when I get home, thansk for the idea
- stavrosgApr 12, 2017Star
I registered the device, cuase i might RMA it. It got progrssivly worse.
I cant imagine this is buggy firmware.
If there is a beta firmware program or if you want logs,I'll happily volunteer.
I love the thing when it works
Stav
- DarrenMApr 12, 2017Sr. NETGEAR Moderator
yea if you believe the hardware is having issues then I suggest contacting support.
DarrenM
