albertoesq
Mar 15, 2017Tutor
Orbi disconnecting continously
I just bought an Orbi Router + satellite, the first 2 weeks where a dream, excelent speed, WiFi everywhere and almost no hickups, but it had been already 2 weeks of nightmare, disconects every 20 minu...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
Netexhausted
Apr 12, 2017Guide
Rbr50 is messed up. I've been doing network (home, peer to peer, remote access) for a long time. Constant intermittent disconnection from the net loss of wireless connection. I went to Device manager and unchecked the power option of the adapters not to allow the adapters to turn off external device. Still didn't work. I was generous with my time and gave Orbi RBR50 opportunity to do what it should. Now I've
given up, back to Cosco it goes. Life is complicated enough I don't need more complications.
