albertoesq
Mar 15, 2017Tutor
Orbi disconnecting continously
I just bought an Orbi Router + satellite, the first 2 weeks where a dream, excelent speed, WiFi everywhere and almost no hickups, but it had been already 2 weeks of nightmare, disconects every 20 minu...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
DarrenM
Apr 20, 2017Sr. NETGEAR Moderator
Hello Wongja
Orbi is not really Ideal for that small of space because your deivces will keep jumping connection between the units causing issues each unit is meant to cover 2500 sq ft.
DarrenM
thebishop
Apr 20, 2017Apprentice
"your deivces will keep jumping connection between the units"
If that is really the case, there seems to be some flaw in the implementation on how steering is done. Why would you ever force a switch as long as the client has a reasonable connection to a given station? One would expect a switch ony when signal level drops below some given threshold? Essentialy acting according to the old adage "Don't fix what's not broken" ;-)
