albertoesq
Mar 15, 2017Tutor
Orbi disconnecting continously
I just bought an Orbi Router + satellite, the first 2 weeks where a dream, excelent speed, WiFi everywhere and almost no hickups, but it had been already 2 weeks of nightmare, disconects every 20 minu...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
Retired_Member
May 02, 2017Are you all seeing the backhaul connection constantly drop if you check using Wi-Fi Analyzer or some other method? When I check, the main 2.4 and 5 GHz signals stay strong but the backhaul(no SSID) drops about every 15 seconds and takes connected devices with it. I also had a perfect Orbi for about a month before slow Wi-Fi speeds and constant disconnects started.
stavrosg
May 03, 2017Star
My backhaul was going through brick, wood, 2 floors down. And I had the disconnects bad. Theory makes sense to me
