albertoesq
Mar 15, 2017Tutor
Orbi disconnecting continously
I just bought an Orbi Router + satellite, the first 2 weeks where a dream, excelent speed, WiFi everywhere and almost no hickups, but it had been already 2 weeks of nightmare, disconects every 20 minu...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
tnadkarni
May 23, 2017Star
Proof of how hard it is to fix I'm having worse results on the beta. It was stable for a while and I got my hopes then my satellite failed spectacularly so much I had to factory reset it and repair to get it to function again. My base router seems fine for now though. I hope they crack this the system is perfect for my use case but I'm running thin on patience.
AkiraX
May 23, 2017Guide
I just updated to version 1.10.1.2, will monitor it for now.
- marshymallowMay 23, 2017Apprentice
AkiraX wrote:I just updated to version 1.10.1.2, will monitor it for now.
Ver. 1.10.1.2 Does not have any resolution to WIFI disconnect Issue.
This is officially acknowledged by Netgear.
- AkiraXMay 23, 2017Guide
Thanks, Marshy.
I was on 1.9 previously, this needs to be figured out before my return period.
I have my eye on a Amplifi HD. I didnt expect to donate testing time to this as its suppose to just work
but I'll ride it for a little. I will now try and monitor my back channel to observe what others are seeing.
Thanks, Marshy.
Netgear is definitely working hard on this wifi disconnect issue.
I'm testing the latest Beta FW and so far in the first 24hrs it's been good.
No drops whatsoever.
There is hope still.
