albertoesq
Mar 15, 2017Tutor
Orbi disconnecting continously
I just bought an Orbi Router + satellite, the first 2 weeks where a dream, excelent speed, WiFi everywhere and almost no hickups, but it had been already 2 weeks of nightmare, disconects every 20 minu...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
jleecloak1
May 24, 2017Apprentice
Can someone upload a copy of the beta firmware?
marshymallow
May 25, 2017Apprentice
jleecloak1 wrote:Can someone upload a copy of the beta firmware?
Please request it through support. Else PM DarrenM Moderator.
- jleecloak1May 25, 2017Apprentice
If the disconnection issue isn't being fixed or the wireless backhaul isn't being added. What is Netgear doing? If you can't fix the major issues what's the point of these firmware changes?
- DarrenMMay 25, 2017Sr. NETGEAR Moderator
Hello Jleecloak1
The disconnect issues are being worked on we are beta testing to make sure the firmware is stable and fixing issues with all types of devices. PM me if you would like to try it.
DarrenM
