albertoesq
Mar 15, 2017Tutor
Orbi disconnecting continously
I just bought an Orbi Router + satellite, the first 2 weeks where a dream, excelent speed, WiFi everywhere and almost no hickups, but it had been already 2 weeks of nightmare, disconects every 20 minu...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
JRE72
Jun 01, 2017Tutor
I requested the beta software. Those that have installed it, I'd love to see more updates as to how it's working out for you!
jleecloak1
Jun 01, 2017Apprentice
I had high hopes for the beta firmware but it doesn't fix the problem. So you might want to stick with your current firmware. I think they really need to pull more people into the development team for Orbi because this problem has been going on for way too long.
