Caspian00
May 05, 2020Aspirant
Orbi disconnecting every few hours (wired and wifi)
Anyone else experiencing Orbi disconnecting from internet every few hours? Both wired & wireless connections. Latest firmware 2.5.1.8
May 05, 2020Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
- Caspian00May 05, 2020Aspirant
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Is the Orbi system operating in Router or AP mode?Mfr: Pace Plc
Model: 5268AC
Provider: AT&T Fiber
Orbi: Is in Router mode
Since i'm experiencing issues with hard wire attached devices too, I think once that's resolved, wirless will be resolved too. I will try disabling all the services you suggested and see if it makes a difference.
Do you think the issue may be that I need to setup a DMZ+ between ATT modem and Orbi? I don't want to put ORBI in AP mode since I lose a lot of it's services.
Thank you for any insights.- FURRYe38May 05, 2020Guru - Experienced User
Yes, since your ISP Modem has a built in router and wifi, you should use the DMZ or IP pass thru for the Orbi in router mode.
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
