Caspian00
May 05, 2020Aspirant
Orbi disconnecting every few hours (wired and wifi)
Anyone else experiencing Orbi disconnecting from internet every few hours? Both wired & wireless connections. Latest firmware 2.5.1.8
T_Duck
Hi there. It's sound just like my problem. But home at me, it's disconnected 24 hour after reboot of the router. the last few days. Can i see after i have keep an eye on it. But strangely i can get access to the router from the WAN:smileyfrustrated: but all LAN on ethernet and wlan is dead, ontil reboot..
I have shot down 2.4 radio, on the router and the sattelite, an use channel 36 on the 5Ghz band. have have static ip address from my ISP
May 05, 2020Guru - Experienced User
Is the RBS wired or wireless connected to the RBR?
Has a factory reset and setup from scratch been performed since last FW update.
T_Duck wrote:Hi there. It's sound just like my problem. But home at me, it's disconnected 24 hour after reboot of the router. the last few days. Can i see after i have keep an eye on it. But strangely i can get access to the router from the WAN:smileyfrustrated: but all LAN on ethernet and wlan is dead, ontil reboot..
Jeg have shot down 2.4 radio, on the router and the sattelite, an use channel 36 on the 5Ghz band. have have static ip address from my ISP
