hamtickell
Jun 10, 2018Aspirant
Orbi disconnecting on Cox modem Arris SB8200
Bought the Orbi in 2017 and set it up in October 2017. Now it is June 2018 and for the past month I have been experiencing frequent disconnects from the internet. Can be resolved by reseting Orbi ...
Jun 18, 2018Guru - Experienced User
What channels are you using? Try manual channel 1, 6 or 11 on 2.4Ghz.
Also try disabling MIMO, Daisy Chain and Fast Roamng.
Any other wifi neighbors near by? If so, how many?
