hamtickell
Jun 10, 2018Aspirant
Orbi disconnecting on Cox modem Arris SB8200
Bought the Orbi in 2017 and set it up in October 2017. Now it is June 2018 and for the past month I have been experiencing frequent disconnects from the internet. Can be resolved by reseting Orbi ...
Jun 18, 2018Guru - Experienced User
What channels are you using? Try manual channel 1, 6 or 11 on 2.4Ghz.
Also try disabling MIMO, Daisy Chain and Fast Roamng.
Any other wifi neighbors near by? If so, how many?
hamtickell
Jun 18, 2018Aspirant
I had it on Auto for the channels, but now switched it to channel 6 per your recommendation. I turned off the Backhaul Daisy Chaining. MIMO and Fast Roaming were already off.
I have neighbors and I can see their SSIDs... we live in a moderately dense neighborhood - houses are about 20 feet apart. Everyone has wifi....
